Invisible ink for iphone7
Pinky14
I cannot get my invisible ink to work... and it's not my rotation or reduced motion... any ideas?
2 REPLIES 2
Can you provide a bit more detail about what you mean by "cannot get my invisible ink to work?"
How is it not working?
WestCoasterBC
Go into Settings, General, Accessibility and Turn Off Reduce Motion. If that fails turn off 3D Touch as well. Test the invisible ink.
If it then works turn 3D Touch back on.
