I need to register my LG phone for telus
RajRai1
2 REPLIES 2
Do you mean it needs to be unlocked, OR that you need to get a Telus SIM card & plan for your phone?
jayman1973
Helpful Neighbour
Hello RajRai1,
In order to register your phone you have to go to LG's website which is lg.ca. You will find at the top of lg's website a box that says "product registration".  Enter the information in to the boxes that have a * in them.  Once you have entered all the info, there are 2 boxes at the bottom of the page check 1 or both of the boxes. Once that has been done then click the box that says REGISTER and everything should be good to go.
