06-21-2013 11:43 PM
if I change my cell number from Albert to BC can I still keep my 10 favourites?
06-24-2013 06:32 PM
This is fine but make sure you let others know of your new phone number so their fave 10 are updated. 🙂
06-22-2013 04:35 PM
Changing your phone number doesn't affect your rate plan in most cases. I have yet to see a favourite number plan that isn't transferable from province to province. 🙂
Hope this helps,
Jim
Client Care
06-24-2013 06:32 PM
02-01-2016 02:14 PM
I want to change my number, i still live at the same place!!! But i've been getting prank call's and annoying txt's from people i don't know... also i want a number that no one's ever used or changed too!! Thank you for your help
02-02-2016 10:40 AM - edited 02-02-2016 10:42 AM
You can block problem numbers on your phone to prevent them reaching you, if you wish.
For many accounts, you can change your phone number in the 'My Account' management section or you can chat with or call Telus and have your number changed. However there is no guarantee that the fresh number you are assigned will be a previously unused number, as when numbers are cancelled, they are returned after a few months to a pool to be used in the future.
See also this post and this one.
