Can't call anyone
013princess013
Organizer
1 REPLY 1
Please don't create half a dozen different posts for the same issue. You will need to provide much more information if you want help.
- Type of phone?
- Does it show cell service / bars at the top?
- Is it on the Telus network?
- Is it yours?
- Have you entered the PIN too many times and the phone totally locked you out?
- Have you called Telus from another phone?
