Apk72's avatar
Apk72
6 years ago
wall mount you telus wifi booster
taking legs out is easy you will need 2 flat screw drivers. On the said wiggle frist screw driver in you booster then right beside it the other then work you way around it will pop out easy. There is one screw I said on the legs take that out and slap the cover back on your done. If this forum allowed pics I would have posted it
