Wyze Cameras and Telus WiFi Boosters
garyyu17
Friendly Neighbour
Hi All,
I hope everyone is having a good day!
I recently installed some Wyze cameras and I noticed it only picked up my 2.4Ghz signal rather than the signal from the Booster (it's actually physically closer to the Booster than my T3200M).
Any reason this would happen?
Also is it possible to have the Boosters broadcast both a 2.4Ghz and a 5Ghz signal?
Thank you in advance!
Hero
Wyze security cameras as well as most WiFi security cameras only support 2.4 GHz connections. This is because 5 GHz doesn't go through walls as well and most security camera installations will need to connect through multiple walls.
You should be able to turn on 2.4 GHz on the booster.
2 REPLIES 2
Hero
garyyu17
Friendly Neighbour
So I finally found out how to connect my Wyze camera to the Telus WiFi Booster.  You HAVE to ensure your phone is connected to the booster when setting up your Wyze camera.
Now I have my Wyze camera connected to the booster.
Thank you to all that replied!
