garyyu17
4 years agoOrganizer
Wyze Cameras and Telus WiFi Boosters
Hi All, I hope everyone is having a good day! I recently installed some Wyze cameras and I noticed it only picked up my 2.4Ghz signal rather than the signal from the Booster (it's actually ph...
- 4 years ago
Wyze security cameras as well as most WiFi security cameras only support 2.4 GHz connections. This is because 5 GHz doesn't go through walls as well and most security camera installations will need to connect through multiple walls.
You should be able to turn on 2.4 GHz on the booster.
garyyu17
So I finally found out how to connect my Wyze camera to the Telus WiFi Booster. You HAVE to ensure your phone is connected to the booster when setting up your Wyze camera.
Now I have my Wyze camera connected to the booster.
Thank you to all that replied!
