October
October
@brettswill Wrote: So I setup the boosters but they wont mesh with the T3200.
Perhaps try the following, just to make sure you didn't miss any of the steps. The Boosters and the T3200M should interconnect with very little problems.
The following video should walk you through the setup from end to end... Cheers...
https://www.youtube.com/watch?v=4QtAij5lK44
October
October - last edited October
@brettswill Wrote: Id like to have all three devices meshed in a single network.
I would just rename either the T3200M WiFi SSID the same as the boosters, or vice a versa including the Password. That way you'll have one SSID Wireless network, and not 2. That should alleviate your problem.
October
November
