brettswill
3 years agoNeighbour
Wifi Hub
Hi all, I moved from an appartment to a house and I took my T3200 with me. The telus tech came and installed it at the new house and gave me a pair of wifi boosters. So I setup the boosters but ...
DrPacman
3 years agoRockstar
brettswill Wrote: So I setup the boosters but they wont mesh with the T3200.
Perhaps try the following, just to make sure you didn't miss any of the steps. The Boosters and the T3200M should interconnect with very little problems.
The following video should walk you through the setup from end to end... Cheers...
https://www.youtube.com/watch?v=4QtAij5lK44
- brettswill3 years agoNeighbourYes, that is the exact process I followed, but even as the video suggests the "new" boost network is seperate from the original T3200 network. Id like to have all three devices meshed in a single network.
- DrPacman3 years agoRockstar
brettswill Wrote: Id like to have all three devices meshed in a single network.
I would just rename either the T3200M WiFi SSID the same as the boosters, or vice a versa including the Password. That way you'll have one SSID Wireless network, and not 2. That should alleviate your problem.
- brettswill3 years agoNeighbourThanks,
Ill have to give that a try when i get home, but I am skeptical. 😉
