Telus Smart Hub is Redwood Meadows and Bragg Creek
MHertling
Has anyone used the Smart Hub in Redwood Meadows and Bragg Creek.
Can someone comment on their service?
Regards,
1 REPLY 1
Hero
It will depend on how close you are to the Telus cell towers. If you are on Telus for mobile your data speed at home will be similar to what you can get on the Smaar Hub.
Check for the nearest cell towers here:
https://www.scadacore.com/tools/rf-path/cell-tower-map-canada/
