04-03-2024 12:34 PM
Thinking of replacing my existing T3200M router plus 3 Arcadyan extenders with a TP-Link Mesh system. My wifi network has been showing some flakiness of late and I'm thinking it's time to move on. I use Optik TV plus but without any Telus custom boxes i.e. Internet only -- Telus Fiber Plus. I assume I would just plug the new router into the Nokia ONT box and proceed to configure my wifi using the TP-Link app. Anyone tried this? My other option is to go with Telus WiFi Plus for another $10 per month.
04-03-2024 09:26 PM
04-03-2024 03:39 PM
Nothing that I've tried personally, perhaps @xray may have some insight into this?
04-03-2024 09:26 PM
04-18-2024 07:54 PM
Well I mad a leap and purchased the new Ubiquiti Dream Router. Not wanting to bring my Actiontec network I am trying the UDR in bridge mode. The UDR seems to think it has been assigned a local IP 192.168.1.1 which should not conflict with anything -- but, when I try to ping this address on the Actiontec Admin client it it times out and there is no sig of this address in any of the 3200's status pages. Probably something simple -- maybe Windows is intervening?
04-18-2024 11:33 PM
04-19-2024 12:43 PM
Tried that -- looks to me as though the T3200m is doing nada wrt to bridge mode. The router linked to 3200 port 1 is showing 192.168.1.1 i.e. the router default -- so it doesn't appear that the 3200m is responding with a served up IP address from its DHCP function (as apparently it should).
04-19-2024 08:30 PM
04-19-2024 08:35 PM
I have tried pinging from the Windows command line without success. The bridging just seems to be inoperative. I am trying to send to router back to Ubiquiti (most disappointing) -- in the meantime I have upgraded my Purefibre to 1.5gb. Maybe a fresh start will lead somewhere positive.
04-19-2024 10:22 PM
04-19-2024 11:20 PM
Good question -- I didn't even get as far as configuring the Ubiquiti because I couldn't get a required Internet connection to run the setup utility. And, you are quite right I should have received an Ip address other than 192.168.1.1 -- it's kind of like a catch 22. Maybe it's possible to do some offline config work on the Ubiquiti and check that it's DHCP capable. Something else I did today was to connect the NOKIA Opt ethernet "out" directly to the Ubiquiti WAN port (after recycling the OPT) -- no difference, same inability to get into the Ubiquiti setup process and in this case no DHCP dimension (presumably). I am getting terminally impatient -- can't understand how Ubiquiti gets such great press (e.g. Garmin) and an almost evangelical following.
Thanks for your help
04-20-2024 03:54 PM - edited 04-20-2024 03:56 PM
Did you try a hard reset on the Ubiquity? I would think the default config is to use DHCP
And you are welcome. It's easy helping people who are willing to do the work to help themselves.
04-20-2024 05:42 PM
Hi Again -- yes I did a hard reset before every attempt to connect, agree DHCP has to be in the default config. Terminally baffled -- the unit just does not seem to want to connect. I have a ticket open with the Ubiquiti folks so we'll see what advice they have.
04-20-2024 06:35 PM
Here is a posting that I just made on the Ubiquiti community site:
Hi Again Travis -- I did finally get around to plugging a wired laptop into Port 1 (bridged) of the Actiontec 3200M and this is what ipconfig showed:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::6f64:dbd1:d302:4c1c%56
IPv4 Address. . . . . . . . . . . : 23.16.98.114
Subnet Mask . . . . . . . . . . . : 255.255.252.0
Default Gateway . . . . . . . . . : 23.16.96.1
So looks like it is getting a public IP so maybe this confirms that the 3200M is in bridged mode. I am beginning to suspect that the UDR that was shipped to me is NFG -- having done more surfing it looks like a ton of folks out there have had the same problem. I have opened a ticket with Ubiquiti: not holding my breath!
April
Finally got the Ubiquiti UDR connected to my home network using 3200m bridging after installing the UDR software offline using a connected laptop. Eureka!
April
April
Indeed!! I spent many hours in my career struggling with what software was supposed to do "out of the box" --- thought things might have improved. The Ubiquiti ecosystem seems to be really sweet once you start to get the glimmer.
