bskitmor
3 years agoAdvisor
TP-Link Deco AX3000 WiFi 6 Mesh System
Thinking of replacing my existing T3200M router plus 3 Arcadyan extenders with a TP-Link Mesh system. My wifi network has been showing some flakiness of late and I'm thinking it's time to move on. ...
- 3 years agoYes, should be a straight swap. I recommend duplicating the same SSID and password with the new router so you don't need to reconfigure any of your devices.
bskitmor
2 years agoAdvisor
Well I mad a leap and purchased the new Ubiquiti Dream Router. Not wanting to bring my Actiontec network I am trying the UDR in bridge mode. The UDR seems to think it has been assigned a local IP 192.168.1.1 which should not conflict with anything -- but, when I try to ping this address on the Actiontec Admin client it it times out and there is no sig of this address in any of the 3200's status pages. Probably something simple -- maybe Windows is intervening?
- xray2 years agoHeroYou need to enable ping in the firewall rules for WAN_LOCAL
- bskitmor2 years agoAdvisor
Tried that -- looks to me as though the T3200m is doing nada wrt to bridge mode. The router linked to 3200 port 1 is showing 192.168.1.1 i.e. the router default -- so it doesn't appear that the 3200m is responding with a served up IP address from its DHCP function (as apparently it should).
- xray2 years agoHeroIf you are pinging from the T3200M it won't work. There is no route to the LAN on the bridged side from the unbridged side. The T3200M Admin page is on the unbridged side.
Related Content
Using a TP-Link router / AXE75, Android boxes, which settings do you change
I'm going to get the new android boxes instead of iptv boxes and fully-bridge my tp-link AXE75 from the NAH, do you guys have any settings on or off that aren't default to make it work? And, if I rem...Solved3.7KViews5Comments
