10-21-2021 08:20 PM
Good day,
Can you the WPS PIN mode on the new TELUS Wi-Fi Hub v3.00.21 build02?
10-22-2021 01:00 PM
I’ve usually used login and password, or the WPS button on the device. Prefer the login process if possible.
10-22-2021 01:00 PM
