Liz_'s avatar
Liz_
4 years ago
Solved
TELUS Wi-Fi Hub v3.00.21 build02 -WPS PIn?
Good day,   Can you the WPS PIN mode on the new TELUS Wi-Fi Hub v3.00.21 build02?
  • NFtoBC's avatar
    4 years ago
    I’ve usually used login and password, or the WPS button on the device. Prefer the login process if possible.
