June
My telus technician to install telus pure fibre connection was supposed to arrive a long time ago but never showed up, none of the support connections help, and if i dont get this done by end of month their shutting down my wifi, what am i supposed to do??
June
There may be a few solutions to your dilemma. Let’s try to point you in the correct direction…
As I understand it you have already contacted Telus via the chat application, correct?
If not, I start there via the following link: https://www.telus.com/en/support/contact-us?linktype=ge-footer#openchat
If you already have an order number for the installation, make sure to inform the CSR agent that will speed the process.
Speaking of an installation number, if you indeed have one than this link may be of assistance to you…
https://www.telus.com/en/commerce/order-status?INTCMP=contactus_orderstatus_AB_V2
and last however not least is a direct connection via the phone.
Technical Support: 1-888-811-2323
Account, billing & sales support: same number: 1-888-811-2323
If you find a post useful, please give the author a "Kudo", or mark as solution if it solves your problem, thank you very much.
