Large amount of RFI between 28 - 150MHz coming from Telus wifi router
zcrow
I am a ham radio operator and the Telus wifi modem/router is throwing out a lot of RFI over a large swath of frequencies. The rfi disappears when I turn the router off but the rfi remains if I turn off the individual wifi radios. Only complete unplugging the router will stop the rfi. These routers should only be sending out signals in the 2.4 and 5GHz bands but are really nailing the lower frequencies. In the 2m amateur band (144MHz - 148MHz) there is a signal spike every 30Khz. Would be nice to have this cleaned up so I can use the frequencies that I am licensed to use without all this interference.
1 REPLY 1
WestCoasterBC
Would be hard to address the hardware from the manufacturer, as there wouldn't be a "fix" as it would be in the PCB board design. Which modem/router do you own?
