How come I have to run a speed test to unlock gigabit
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-13-2024 01:27 PM
https://youtu.be/I_srizrCYI8
See above. My connection consistently throttles to kilobytes until I run Telus' speed test. After, and ONLY after, I run that, my speed goes to the rated speed where it will stay for the next five or ten minutes before dropping off again.
I found this out while trying to upload a YouTube video a while back and it has consistently been the case. I feel bad for people who bought gigabit but only get it when they run a Telus speed test but get silently throttled every other time.
3 REPLIES 3
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-13-2024 02:39 PM
Which wireless router are you using? What happens if you try uploading from a computer connected to ethernet?
If you find a post useful, please give the author a "Kudo" or mark as an accepted solution if it solves your trouble. 🙂
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-13-2024 02:49 PM
I doubt running a Telus speed test and getting uncapped bandwidth so Telus can point to the speed test and say I am getting rated speed has anything to do with what hardware I am using. This is just pure shady. It appears to be at the service level.
The same throttling occurs when using my mobile for uploads through both the included telus router as well as downstream through a very nice GT-AX11000.
It will also occur on PC with hardwire.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-14-2024 07:22 PM
https://youtu.be/VF4K89pFFDs Heeeere we go again. From x kbps to 20 Megs
