- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-21-2022 12:20 PM
Wanting to setup a VPN server at home for remote access to my home network while aboard.
I know some ISPs do not allow this - will Telus allow for incoming Wireguard or OpenVPN connections?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-21-2022 01:18 PM
@Benedmonton Wrote: will Telus allow for incoming Wireguard or OpenVPN connections?
I have a separate Wireguard VPN server running just fine on my system here, Its run consistently for a couple of years without any problems at all..
If you find a post useful, please give the author a "Kudo", or mark as "Solution", if it solves your problem, thank you very much.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-21-2022 01:18 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-22-2022 06:49 AM
Telus does not block running a VPN server, I have IPSec, L2TP, and OpenVPN all running fine. For PPTP, you will need to forward protocol 47 (GRE) which the Telus router may be incapable of doing, I would definitely suggest using your own router for this.
