Benedmonton's avatar
Benedmonton
Friendly Neighbour
3 years ago
Solved
Does Telus home allow for internet incoming VPN?
Wanting to setup a VPN server at home for remote access to my home network while aboard. I know some ISPs do not allow this - will Telus allow for incoming Wireguard or OpenVPN connections?
  • DrPacman's avatar
    3 years ago
    Benedmonton Wrote: will Telus allow for incoming Wireguard or OpenVPN connections?
    I have a separate Wireguard VPN server running just fine on my system here, Its run consistently for a couple of years without any problems at all..
    If you find a post useful, please give the author a "Kudo", or mark as "Solution", if it solves your problem, thank you very much.
