March
Hello,
So i recently got the new wifi6 switched from shaw installation went great and everything but i cannot access router settings since my ps5 and switch are only on 2.4 ghz and my sons xbox and everything is on 5 ghz is there anyway to fix this i am unable to hard wire but i need a stronger connection to stream and play online. i have a admin password on my booster and all that but no admin ive went into my the ip and dont know my user name. its not on my router so im kinda lost
March
If you did not change anything on the wifi 6 unit, then the username and password should be the one on the unit where you can see "admin" username.
March
Username should be ‘admin’.
March
Alright so here is the kicker now the admin password on the router is wrong i checked the boosters too its all wrong
March
