ferentes
7 months agoNeighbour
Telus Pure Fiber - how to bypass NH20A with a media converter?
Hello,
Perhaps it has been discussed but I could not find an exact situation fit.
I have just switch from Bell to Telus in Ontario and the following setup worked fine for a long time.
I have plugged Telus SFP into a TPLink Media converter, entered PPPoE credentials in my PFSENSE router, VLAN to 40/Priority0 assigned to the WAN port.
The setup does not connect to the internet, media converter lights all green.
However if I move SFP to the NAH20A in bridge mode with the same PPPoE creds and VLAN it connects fine.
What could be wrong with the PFSENSE-Media Converter setup?
- ferentesNeighbour
Thank you! #3 helped.
- TELUS_Support
Awesome! Let us know if you ever have any other questions, and thanks for posting in our community!!
- TELUS_Support
There are a number of things it could be:
- MTU configuration (a possible option would be to set it to 1492)
- Authentication timing issues (could try setting LCP Echo Interval to 30 seconds and Echo Failure to 3)
- VLAN Interface (make sure it's configured on the physical interface before PPPoE)
- Interface settings in PFSENSE (try setting it to full duplex, 1000Mbps)
The last thing to attempt if you haven't tried it yet would be a full power cycle.
Related Content
- 7.4KViews4Comments
