ferentes's avatar
ferentes
1 year ago
Solved
Telus Pure Fiber - how to bypass NH20A with a media converter?
Hello,  Perhaps it has been discussed but I could not find an exact situation fit. I have just switch from Bell to Telus in Ontario and the following setup worked fine for a long time. I hav...
  • TELUS_Support's avatar
    1 year ago
    There are a number of things it could be:
    - MTU configuration (a possible option would be to set it to 1492)
    - Authentication timing issues (could try setting LCP Echo Interval to 30 seconds and Echo Failure to 3)
    - VLAN Interface (make sure it's configured on the physical interface before PPPoE)
    - Interface settings in PFSENSE (try setting it to full duplex, 1000Mbps)
    The last thing to attempt if you haven't tried it yet would be a full power cycle.
