Jurmalurm
3 years agoNeighbour
Wall mounting smart home control panel
Hi there,
I have a installation scheduled, I would like the control panel mounted, I have a place directly above an outlet - I want to put the power cable in the wall, will the technician be able to facilitate that? Or would I need to do it myself?
Generally the home owner does the fishing of walls, the installer may or may not do this for you since a short run. You can always prep it and have the holes ready with a pull wire for the installer.
- NFtoBC
If it is an interior wall, they should fish the wire from the point of installation to an outlet directly below, at least they did for me.
- WestCoasterBCCPU Alum
The user is talking about the alarm panel
Related Content
- 7.4KViews5Comments
