Jurmalurm
3 years agoNeighbour
Wall mounting smart home control panel
Hi there, I have a installation scheduled, I would like the control panel mounted, I have a place directly above an outlet - I want to put the power cable in the wall, will the technician be able to ...
- 3 years ago
Generally the home owner does the fishing of walls, the installer may or may not do this for you since a short run. You can always prep it and have the holes ready with a pull wire for the installer.
3 years agoIf it is an interior wall, they should fish the wire from the point of installation to an outlet directly below, at least they did for me.
Related Content
- 7.5KViews5Comments
