Jurmalurm
3 years agoNeighbour
Wall mounting smart home control panel
Hi there, I have a installation scheduled, I would like the control panel mounted, I have a place directly above an outlet - I want to put the power cable in the wall, will the technician be able to ...
- 3 years ago
Generally the home owner does the fishing of walls, the installer may or may not do this for you since a short run. You can always prep it and have the holes ready with a pull wire for the installer.
polecat
3 years agoAll-Star
Jurmalurm The telus tech dos not do power wiring that is up to you. When you wire the outlet put in 4 outlets ( ONT - MODEM ROUTER - BATT BACKUP FOR PHONE IF NEEDED - AND WHAT EVER ELSE )
- WestCoasterBC3 years agoCPU Alum
The user is talking about the alarm panel
Related Content
- 7.5KViews5Comments
