pm1804's avatar
pm1804
3 years ago
Solved
Sensor armed away and then flips to armed stay
Hi ... I've been experiencing an issue when my employees lock up for the evening. They arm the system on the panel for "Armed Away" and then lock the front door and leave. Exactly one minute after th...
  • A-B's avatar
    3 years ago
    Hello. I'll send you a private message so we can discuss our options further, thanks.
  • LongtermCustome's avatar
    3 years ago
    Hello, I'm having the exact same issue, can you please help me out?
  • A-B's avatar
    A-B
    3 years ago
    I'll send you a private message.
  • A-B's avatar
    A-B
    2 years ago
    I do know one common reason is the system being armed while one window, door, etc. is ajar. Have you checked everything before arming to see if that's the case?
