Telususer9797Neighbour4 years agoWPS on wifi hub arcadyan Do you recommend disabling WPS if its a push button configuration (PBC)?
Related ContentWifi Hub LAN1 Bridge mode (arcadyan) What is the point of this mode? What kind of setup does it allow you to do? From my understanding you connect another router to the lan1 port and then you have 2 independent networks that can't commu...Solvedarcadyan telus wifi hub The arcadyan telus wifi hub claims to support z-wave and zigbee. Does anyone know if it supports the new matter iot standard or if there are any plans for it to do so? SolvedWPS securityHello, Just wondering if anyone knows how secure the WPS is on the Telus’ modems. Is it something that you’d leave on by default or something that should only be enabled when you need to use it? Th...SolvedPVR VIP5662W and TELUS WIFI HUB (Arcadyan) Hello, Is the VIP5662W WiFi capable? I think it is, but I have it currently connected via ethernet but want to move it where there is no ethernet outlet. How do I connect it to my Arcadyan to the T...SolvedArcadyan Bridge mode I have a sonos system. With a recent update, the desktop control system works, but the App (Apple & Android) don't find the system. After 30+/- minutes with Sonos support, I was told that the only s...Solved
Recent DiscussionsCancelling contract during grace periodSolvedMovingUnable to Manage Internet PlanAndroid box turning my TV off.Access APPLE TV with Optik TV account
