RonAKA
7 years agoRockstar
- 7 years agoIs Smart Steering turned on? If so try turning it off. You will need to create a separate SSID for each WiFi band (2.4 GHz and 5 GHz) so keep the SSID for the band used by the most devices and create a new SSID for the other band.
RonAKA
6 years agoRockstar
I am now on day two of no dropout after switching to a fixed IP, AND resetting the router and Networks on the iPhone. But I have gotten up to 4 days with this router reset and network reset before, so I am not real optimistic of it being a permanent fix. It is puzzling why I can get a temporary fix for days but then it goes wonky again.
RonAKA
6 years agoRockstar
That last fix did not work. On Dec 19 I tried another solution. That was to reset the router, clear the iPhone network settings, and assign a fixed IP for the iPhone, and then sign into the 2.4 G side of the router. That would now be the only item on 2.4 G. It has been 8 days now, and that is twice as long as I have gone before without a dropout. I hope this isn't bad luck, but (for about the 4th time), I may have a solution. It would seem that my iPhone on iOS 13 does not like 5 G routers, or at least it does not like to share that band with others on the same SSID.
Related Content
- 3.4KViews8Comments
