RonAKA
7 years agoRockstar
- 7 years agoIs Smart Steering turned on? If so try turning it off. You will need to create a separate SSID for each WiFi band (2.4 GHz and 5 GHz) so keep the SSID for the band used by the most devices and create a new SSID for the other band.
RonAKA
7 years agoRockstar
After separating the 2.4G and 5G bands and moving all of our connections to the 5G yesterday afternoon, and then doing a Network Reset on my iPhone and powering down the router and back up again, there have been no dropouts of my WiFi. I did power the iPhone right off overnight, but it has been on today since 8:00 AM, and is still OK. That is the good news. The bad news is that I have gone this long before after doing the network reset and power down of the router trick, but it never seems to "stick" long term. Will be interesting to see if it does this time...
Any thoughts on what the power down of the router and network reset on my iPhone would be doing? And even more importantly why it may not "stick" as a permanent solution?
RonAKA
7 years agoRockstar
Well it has been 4 days now and no real dropouts of my WiFi. I did get a short delay once today, but it connected. It looks like the combination of disabling the SmartSteering and switch my network SSID to the 5G band may have solved the problem, after I powered down and powered up the router, and reset the network settings on my iPhone, in addition to resetting the band. I'm hoping!
Related Content
- 3.4KViews8Comments
