RonAKA
7 years agoRockstar
- 7 years agoIs Smart Steering turned on? If so try turning it off. You will need to create a separate SSID for each WiFi band (2.4 GHz and 5 GHz) so keep the SSID for the band used by the most devices and create a new SSID for the other band.
7 years agoHero
RonAKA wrote:I guess I am wondering what happens when I Disable SmartSteering. What will I be presented with for options?
Take inventory of all your devices and count how many are 2.4 GHZ only vs 5 GHz. Keep your current SSID for the frequency that has the most devices to minimize the number of devices you need switch to the other frequency.
RonAKA
7 years agoRockstar
How do I tell which ones are on 2.4 GHz vs which ones are on 5 GHz? I see a list of devices and you can tell which ones appear to be hard wired (full duplex) and which ones are wireless, but how do you tell what wireless frequency they are using? And with SmartSteering, I presume that changes?
Related Content
- 3.4KViews8Comments
