brettswill
4 years agoNeighbour
Wifi Hub
Hi all, I moved from an appartment to a house and I took my T3200 with me. The telus tech came and installed it at the new house and gave me a pair of wifi boosters. So I setup the boosters but ...
DrPacman
4 years agoRockstar
brettswill Wrote: Id like to have all three devices meshed in a single network.
I would just rename either the T3200M WiFi SSID the same as the boosters, or vice a versa including the Password. That way you'll have one SSID Wireless network, and not 2. That should alleviate your problem.
brettswill
Thanks,
Ill have to give that a try when i get home, but I am skeptical. 😉
- brettswill4 years agoNeighbourDrPacman
I got home recently and tried renaming the SSID to be the same and that cause a whole bunch of problems.
I ended up goj g into a telus store and they say this is a common request/problem. Telus is sending me a replacement WIFI Hub.
So yay!
