Yatsukin
6 years agoFriendly Neighbour
WiFi Boost and Ethernet
Hi everyone, I've just set up my two Wifi Boost sets, and I'm wondering whether the original one needs to stay connected to the router through the ethernet cable, or whether I can remove it and p...
- 6 years agoYou need the first boost to be connected by Ethernet to the router. The boost units run their own mesh network separate from the WiFi the router runs. You should disable the WiFi on the router to avoid interference and signal congestion.
6 years agoHero
Yatsukin
Thanks again, xray. How do I disable the wifi on the router? Will that change the name or the strength of my network?
