darksorcerer
7 years agoHelpful Neighbour
Website Blocking Not Working
Hi,
This is an invalid solution
https://forum.telus.com/t5/Internet-Home-Phone/Does-Telus-have-an-ISP-Level-blocklist-we-can-use-Router-level/td-p/85107
Not sure why this thread is lo...
Telus2000
6 years agoNeighbour
SOLVED! (I hope) just spent 2 hours on hold to get through to tech. NSFW sites can be blocked and managed via the Telus Wifi App (not the modem) you'll need to download the app and manage the sites via the app. Apparently this is only needed for the T3200M (black modem) and the new white modem (fibre) does not require this.
- Spinach6 years agoNeighbour
Telus2000 could you tell me where this is in the app? I've been searching and searching.
I'm honestly ready to leave telus for shaw over this.
- Nighthawk6 years ago
Did you try: https://www.google.com/search?q=Telus+Wifi+App&hl=en ? Telus only has the one My Wifi app currently. I don't recall seeing the ability to block websites in it though.
- amam6 years agoOrganizerWow you would think felus would've been more helpful instead of making you waste so many hours! I also know that's been an issue. Just simply doesn't work! Also the Telus wifi app is GLITCHY at best. Good luck!
