dan1234
3 years agoNeighbour
using UniFi access points with Telus wifi hub (arcadyan)
Hello! I have a telus wifi hub (arcadyan) in the corner of my house! Pretty bad coverage. I have 2x UniFi wifi 6 lite's hard wired (main floor and second floor) and am running a switch which can do P...
dan1234
Thank you for the detailed reply! I have 2 more quick follow up questions if possible.
1. For the set wifi name/password in step 5, is that the same wifi name/password that I initially set up on my telus router? Will it automatically act as a mesh network, using the strongest signal it sees?
2. Will the original telus router still be sending its own wifi signal, and this new Unifi AP will be a second point of said signal?
Thank you for the help!
DrPacman
3 years agoRockstar
dan1234 Wrote: For the set wifi name/password in step 5, is that the same wifi name/password that I initially set up on my telus router?
No, the will be the one that is set in the Unifi controller as it as the name implies controls all the Ubiquiti Unifi devices on your network.
The Telus router will still send its own Wi-Fi signal as you refer to it, that is unless you disable that segment in the router itself..
Cheers...
If you find a post useful, please give the author a "Solution", or mark as "Kudo", if it solves your problem, thank you very much.
