mailwbc's avatar
mailwbc
4 years ago
Solved
Turning off T3200M Wifi and using instead a Linksys Velop AX4200 WiFi 6 Mesh System
Hello,
I was looking to do the above and noticed another user posting difficulty with their LAN and WLAN speeds after putting in place a similar setup (see user's posting at bottom)
Can you advise on the configuration settings that should be used on both the T3200M and Linksys AX4200 to ensure the optimal performance?
I'm on a Telus Gigabit Internet fibre connection. I am somewhat savvy with the concept of what is being done but need some detailed guidance in the best settings and method to connecting the T3200M & AX4200 together.
Thanks kindly in advance for any assistance that can be provided.
cheers....Bill :-))
User posting from: https://forum.telus.com/t5/Internet-Home-Phone/T3200M-Bridge-mode-and-Google-Mesh-WIFI-Setup/m-p/105089#M24412
BobtheBuilder ‎04-18-2020 01:26 PM
I had similar idea, but linksys velop instead of google nest. I had similar success with
Nokia Fiber Modem > T3200 in bridge mode + wifi turned off (I found some smart devices were still getting confused and dropping WiFi connections)
T3200 > Velop Parent Node
Velop > Switch > Wired LAN connections
Velop > Child Nodes > Wireless LAN connections
All Cat 6+ cabling
I'm on the fibre 150 plan
The issue I still have Is both LAN and WLAN speed tests both won't exceed 100 Mbps (~95 is the max I get)? Anyone have any idea on what is limiting it? I've tried testing at both peak and non-peak (ie. middle of the night) and it's always between 75-95 mbps (using fast.com site for testing).
  • Nvrm.....solved my own question by trying it out and it was quite easy with this new Linksys unit.
    Key things:
    1. Disable Actiontec wifi by logging into the Telus admin page at 192.168.1.254 using a computer connected with an ethernet cable to the modem
    2. connect the ethernet cable to the Internet port on the Linksys unit and not one of the LAN ethernet ports
    3. download the Linksys mobile config app (for iOS or Android) & use that to do the Linksys setup but follow the directions carefully on the app & DONE
    I have 2 Optik TV units and the above process did not affect them and no bridging or any other fancy network setup or configuration changes needed
    So in the final end, the Linksys Velop AX4200 WiFi 6 Mesh System process was a breeze and all the WiFi 6 devices can connect at optimum speeds and at much better distances without any performance hits on the connection speeds.
    Key things:
    • xray's avatar
      Hero
      Are your Optik boxes connected by Ethernet to the T3200? This is the preferred setup as many 3rd party routers have problems with multicasting. This is how my network is set up. The added benefit is that TV traffic is not mixed in with any of your local LAN traffic on the Linksys.
      • mailwbc's avatar
        mailwbc
        Yes, that’s pretty well how it looks to be.
        Anyways, it all seems to be working now and the only other thing aside from the things I listed before , was to put the Linksys Velop AX4200 into Bridge mode so all the devices on the network could be seen together
