MikeyR
2 years agoNeighbour
TELUS TV+ Remote AV Receiver Power Control
Hi, new to TELUS TV+. So far so good. I got the remote to control my Sony TV and change the volume on my Pioneer av receiver. When I hit the power button on the remote, the TV shura off, but not the a...
- 2 years ago
Did you pair the TV remote with your receiver? If not, have a look at this FAQ and check out the Pairing your TELUS Remote to AV receivers and soundbars section.
dru
Community Manager
2 years agoDid you pair the TV remote with your receiver? If not, have a look at this FAQ and check out the Pairing your TELUS Remote to AV receivers and soundbars section.
- MikeyR2 years agoNeighbourYes, that’s how I control the volume.
- RobG39872 years agoAmbassadorI had asked the same question many months ago and never got an answer or resolution.
Ironically I ended up still using my remote I had left over from Shaw just for the turning on/off of both the TV and audio receiver together as the Telus remote wouldn't do it,,, for some reason that nobody could answer.
I went through all the pairing codes available for the receiver, and like you, it could only manager volume control.
I gave up considering I don't anticipate staying with this Telus system long enough to bother.- MikeyR2 years agoNeighbourYa, I’ve seen a couple posts with no responses. Luckily these boxes work with IR and I can keep my Harmony/Logitech remotes. All this ‘smart’ technology today and my old 880, 650, and 665 still blowing it away. I had big hopes for this remote…
