ArneSalvesen
7 years agoNeighbour
Bobbychomes
iPhone 8, iPhone 7, 2018 MacBook Air, 2019 iPad Air, 2017 iPad, 6th gen iPod are what disconnects. Our Globe brand wi-fi light bulbs are also offline can't seems they can't connect as well.
Powderjockey
7 years agoAdvocate
The Globe brand WiFi bulbs only work on a 2.4 Ghz frequency. If you disable SmartSteering on the main router and connect you phone/ipad you should be able to connect to the bulb.
I've noticed if the bulb is off, it will tell you the bulb is off line. Once the bulb comes on, it will show online. This all assuming the bulb has been initially set up.
