jjdinks
2 years agoFriendly Neighbour
- 2 years ago
jjdinks
Thanks,
The fibre was first installed 2-years ago I think. It was when Telus was rolling out fibre in Edmonton.
I'm pretty sure my home phone line will be okay right? I just need to get rid of that adapter and run a straight ethernet to ethernet connection from the T3200M and ONT.
Would Telus be able to fish this ethernet to ethernet port for me?
Anonymous
2 years agoYes your home phone line will not need to be changed , it is ok as it is from the ont to the ethernet , adsl adapter.
- Nighthawk2 years ago
- jjdinks2 years agoFriendly NeighbourNo, I could probably find some videos online or just use the existing DSL run to the T3200 and use that to fish the new ethernet cable in.
As for my home phone, I am pretty sure it is not on fiber so its not being connected from the ONT. I believe this is true because on the MyTelus website I am offered the option to switch the home line to fiber.- ApprovedAnonymous2 years ago
Your home phone line is on a separate line, on the existing copper line.
The ethernet is on a separate line, then a ethernet cable run between the ont modem and the adsl, ethernet adapter.
- jjdinks2 years agoFriendly Neighbourso ethernet cable from ONT to T3200 right so that I get Gigabit from the T3200?
No adapters needed right?
And to once again confirm, I will need to make this cable run myself?
