floppydiskhero
6 years agoFriendly Neighbour
Switched from 75/75 to Gigabit plan, problem with upload speed.
I recently switched from 75/75 plan to gigabit. With that change, my modem was swapped from the T3200 to the new Wi-Fi Hub. This is the only hardware change in my system. Before the change, my h...
BillTelusCust
6 years agoRockstar
So if you are getting full speed further upstream from the Telus speedtest server, something on Telus' server is broken - and you are getting 10% less speed than you should. Why not tell them that you "know" they are not in control of the internet, but they need to prove that their local loop is up to the speed specified. this will force them to fix their speed test server. If you can't do a speed test on their local server, try one in another Telus location - they have several. Or try a Telus mobility one.
Might as well keep on them till they fix it.
6 years agofloppydiskhero What app are you using on your PC to test your speeds? If you go to speedtest.net and choose Telus as the server from the closest city to you, do you see an upload speed from your PC? It's entirely possible the app itself could be the issue. If the app shows normal upload speeds to other servers, it's likely still related to the app. Knowing which one you are using can help. Also since there are several Telus speed test servers, which city is the Telus speed test server in that you are testing to?
Try fast.com from your PC. It's very low overhead, unlike speedtest.net. It also can easily handle gigabit+ connections. No app to spy on your PC either.
BillTelusCust Telus Mobility reps aren't going to be dealing with anything related to non-mobility services. The fibre tech support typically won't be able to either depending on who built the app in question and what the actual issue is. They won't have any access to the speed test server.
- floppydiskhero6 years agoFriendly Neighbour
Thanks for the reply.
I have used the SpeedTest app, as well as SpeedTest.net with the same results. I am choosing the Telus server for Calgary (my city) and I see an initial spike of about 1.5mbps, then it tapers off to 0mbps. If I choose, say, Axia Connect LTD. (also in Calgary) I get 940mbps download and upload.
I have tried fast.com as well with less than favorable results. It generally shows 400mbps download speed and 1.5mbps or lower upload speed.- Nighthawk6 years ago
I have no problems getting speedtest.net etc to show the upload speed to the Telus speed test server in Calgary.
It's weird fast.com didn't work for you. I tend to get more consistent results there than I do with speedtest.net.
It sounds like your internet is working fine. 940mbps is the advertised maximum speed you'll see. The third party app/website from speedtest.net is more likely to be part of the issue. Speedtest also mentions on their support pages that some users antivirus or firewall could result in a zero upload speed also.
Beyond speed testing, I have noticed hangups and slow loading (sometimes not loading at all) pages in multiple browsers, as well as worse latency numbers while gaming. Pretty disappointing really coming from 75/75 and experiencing worse performance now.
I'll look into the firewall, however I am only using Windows 10 firewall/anti-virus and it was not causing me issues before with my previous internet package.
