SpeedyDinosaur
6 years agoFriendly Neighbour
Speed slowly gets to normal on speedtest
Hi, Something odd that I have noticed was that whenever I do a speedtest, my download and upload speed will slowly ramp up to the speed I pay for. Before when I started the speedtest it would go ...
- 6 years ago
You have subscribed to a top of the line internet package. Need to remember that in most of the world they don't see a fraction of this and consumer routers simply aren't build to deal with that kind of speed, especially if you enable some sort of encryption on them.
Very easy way for you to see if the home router is cause of your slowdown.
Now that home router is on port 1 in bridged mode, unplug the RJ45 from your PC that goes into the home router and plug it directly into the modem in one of the other free LAN ports and run the same speed test. If you don't get the slowdown you see with your previous setup its time to either reconfigure or replace the home router.
If / When you add on router encryption/vpn to get line speed with your good fibre connection you need some serious specs most consumer hardware cant handle this.
Here is just one example of the hardware (and cost) scaling when you get into speeds the big boys are playing at.
https://www.netgate.com/products/appliances/
I have no affiliation with Netgate, however I do custom build routers using the same open source Pfsense platform.
SpeedyDinosaur
It looks like it uses the same speedtest.net system, but I ran it and it was the same, it would slowly ramp up.
Foonus
6 years agoAmbassador
I asked you to run the second test just in case there were some issue with peering that their direct link may resolve but looks like that is not the problem.
Unless this is an extremely old/tired machine PC it shoudn't be this bad.
Not sure why you are seeing the ramp up as much as you are, however I agree with you that it is not normal.
This location is only on the 750/750 but it literally starts instantly at 720 and ramps up to 760-800 both up and down.
In your Telus modem settings, you do have port 1 set to Bridged mode?
What happens when you plug your PC into one of the other ports on the telus modem and bypass the second router? Is it any better?
- Foonus6 years agoAmbassador
Also worth mentioning, I saw similar results though not as drastic when i swapped browsers to MS Edge with Windows 10 Pro Build 2004 with the "Application Guard for Microsoft Edge" running.
Try with Firefox if you were using Edge and see if it is any better, might be as simple as the windows update changing the way Edge was running on your machine.
- SpeedyDinosaur6 years agoFriendly Neighbour
Also, what does bridging port1 exactly do? Thanks for replying by the way
I don't think browser was a problem, I was using chrome.
I turned port1 bridge on in the telus modem settings, and now I can't access the telus modem webpage on my second router network, is that normal?
I also restarted my router and used a different ethernet cord and the speed still ramps up but it's signifcantly faster and I hit the maximum speed by the end of the speedtest.
However when I plug in the ethernet cord directly from the modem to the computer, there is almost no ramp up and I believe it hits the maxium speed faster. Is there a problem with the second router that's bridging the modem to my computer?
Ideally if you are using a third party router with the 3200 modem it will be set (the modem) to port 1 bridged mode. You hook your home router then to port 1. Simply this allows port 1 to act as a pass through to allow your router to handle routeing instead of using the modems built in routing. This is why you can't access the modems admin page through your home router. This is normal/good, if you need to access it plug into any of the other 4 LAN ports on the T3200M.
For now you are already better off because you had double NAT situation you fixed by enabling the bridged mode. Which home router are you working with?
Related Content
SpeedTest Results fine, but Upload is very low on Fibre Gigabit plan in most tests
Just wondering if someone can chime in here. I used Telus Fibre for about 9 years. Never had any hiccups until I moved cities into a condo. For the first few months it was great, after that its been ...297Views2Comments
