Ray77
3 years agoNeighbour
Speed Test from T3200m shows 350/250, suppsed to be 940/940
How can I have Gigabit speed back? I've made 3 times' calls to tech support. Just hour ago, I made another call and the agent kept saying 400(D)/300(U) seems right since the speed test took pla...
- 3 years ago
Speeds over wireless are never guaranteed. Too many variables that can affect it.
Ignore the speedtest in the admin section of the T3200. It's broken. I get 362/273 from the T3200 speed test but 944/948 from speedtest.net when on a hardwired computer. What do you get if you run a speed test from a hardwired computer?
3 years agoSpeeds over wireless are never guaranteed. Too many variables that can affect it.
- Ray773 years agoNeighbour
Thanks Nighthawk for your answer.
You're right. The result from T3200m and SpeedTest.net (wired) shows totally different output.
Mine is 928/849 which is very good for my usage.
I owe big apologies to 3rd Telus technician who tried to help me several hours ago.
And thanks Nighthawk and big thanks to 2 previous Telus technicians who spent hours trying to fix it.
