CanadianKodiak's avatar
CanadianKodiak
Friendly Neighbour
5 years ago
Solved
Smart Hub Pairing with Router
Is it possible to wirelessly pair my Netgear router with my Telus Smart Hub?  I don't want to have to run an ethernet cable from my router to the Smart Hub.
  • CanadianKodiak's avatar
    CanadianKodiak
    5 years ago
    Although I greatly appreciate your help I have to correct you on your last post just in case anyone else is attempting to do what I just did.  I purchased a wifi extender and was easily able to connect it to my Telus hub using WPS.  I then connected my Netgear router to the extender using an ethernet cable and voila!, everything is working as planned.  Thanks again for your help, though, it really is appreciated.
