magg992001
6 years agoNeighbour
Smart Hub is limited wifi.
The Smart Hubs are limited to wifi connections. I have a ZTE MF279T and am always struggling with having to shut off connected devices, cameras, kids devices etc. etc. Is there something I can do t...
Campbellis
5 years agoNeighbour
Maximum number of wifi connections 10 🤔
adamthebad
5 years agoAdvisor
greetings
my Telus 279 rural router will NOT go above 10 direct wifi connections and I have been using it for just about 60 days (new unit).
The only way to go above 10 wifi connections is to turn the Telus 279 in to a gateway and use an external router usually goes above 50.
NOT all rural homes are limited to 10 wifi connections like TELUS thinks we should have. In some cases it more the a city home PLUS to get a 279 rural router TELUS actually canceled my first try to get a router saying i have no cell connection where i am!
- xray5 years agoHero
"NOT all rural homes are limited to 10 wifi connections like TELUS thinks we should have"
The limit of 10 connections per frequency is determined by ZTE the device manufacture. Rogers and AT&T use the same device and have the same limitation.
- adamthebad5 years agoAdvisorProblem solved! Woohoo!!....the Telus ZTE MF279 gets tossed. No more freezing and limitations. NightHawk LTE Modem wiith Nighthawk Long rang Router...Clear sailing
- cajr8885 years agoNeighbour
Did you actually replace the ZTE MF279 with the Nighthawk? Or in addition to it? (I'm kind of new to this.) We have spent hours on the phone with Telus because our MF279T just stops - randomly. All of the devices are connected but it won't talk to the outside world.
- k2spirit8395 years agoCoach
The zte mf279t smarthub is a duel band wifi router. So it has 2.4GHz wifi band and 5GHz wifi band. Either band can handle 10 wifi devices. So the 2.4GHz wifi band has 10 wifi devices and the 5GHz wifi band has 10 wifi devices. So the hub can handle 20 wifi devices at any given time.
- adamthebad5 years agoAdvisora limited proposition at best!!...where some systems will only run or engineered to run on 2.4G. the whole electronic world still has not adopted 5G signals...When a side router is put into this scenario its 50 either way (2.4/5) with no limitations.
- RonAKA5 years agoRockstar
If you can separate the two bands and set up two independent WiFi networks, one for 5G and one for 2.4G, you will have more control. The 2.4G band has more range than the 5G. You could sign on the more distant (weaker signal) devices to the 2.4 G.
- adamthebad5 years agoAdvisorGreetingsfollowup...by turning the telus 279 rural hub into a gateway and not use it as the modem actully increases speeds slightly as I can remotely control/check cameras/devices quicker.5G signals across ten acres (almost 436000sq.ft.) requires way to many upgrades as with 2.4G which is way more cost effective.As for a urban setting which i also have the telus unit is also just a gateway as well because of the Minimal setup to get by for the price paid....so again a external performer is attached to provide a wider faster gain in performanceOn Oct. 14, 2020, at 10:00 a.m., TELUS Neighbourhood < telusneighbourhood > wrote:
Hi adamthebad,
RonAKA (Ambassador) posted a new reply in Internet & Home Phone on 10-14-2020 10:00 AM:
Re: Smart Hub is limited wifi.If you can separate the two bands and set up two independent WiFi networks, one for 5G and one for 2.4G, you will have more control. The 2.4G band has more range than the 5G. You could sign on the more distant (weaker signal) devices to the 2.4 G.
You are receiving this email because a new message matches your subscription to a topic.
To control which emails we send you please go to, manage your subscription & notification settings or unsubscribe.
