MonkeyRPN
6 years agoOrganizer
Slow speed on booster even when wired?
Hello... I hope I’m able to find a solution here for my problem with the experienced members. I have this weird spot in my basement that I’m unable to get my Telus Booster to maintain acceptable speed...
polecat
6 years agoAll-Star
MonkeyRPN the common thing here is that patch cable. Bad cable bad ends???? Try a wifi signal strength app i use ( matthalfner.com ) shows all nearby wifis and their strength. I your case both 2.5and 5 ghz. Minus 48 0r 50 at 30 feet away good -60 still ok -70 your are on the edge. I have 25/25 with 28 up and down all the time and - 48 using 2.5 ghz at 30 feet The 5ghz is at -72 to -78 at 30 feet. I get -35 at 10 feet. Correct colors on patch cable? I can see over 30 wifi sites up to 3 blocks away. you might want shut off smart steering on the 3200. Polecat
