newio
2 years agoOrganizer
Recording and fast forward, rewind
Can you fast forward and rewind while a recording is still in progress? If it is 30 minutes in of a 60 minute program, can you start watching it and ff/rewind within the first 30 minutes?
Can you go back and replay something in live tv like on hard drive PVRs with a constant 1 hour ring buffer? Can you slow-mo replay it?
Can you do a real fast forward at different speeds, or is it just jumping back and forth? I was reading the following and wondered if it had been fixed or addressed or will be soon?
https://old.reddit.com/r/telus/comments/1987goc/anyone_else_hate_the_androidtv_telus_boxes/kowqy60/
- newioOrganizer
Thanks. I hope it continues playing after it reaches the live point as more of the program will have been broadcast by then. I am trying to avoid commercials but still use live TV easily as one normally does with a PVR.
What about a Live TV ring buffer allowing ff/rw within it? PVRs have had them for decades and Bell Fibe TV has it:
https://www.mythtv.org/wiki/Ring_Buffer
For slow-mo, maybe like Youtube "." and "," keys, letting you see frame by frame. Slow-mo seeing things is very useful in sports. Fast forwarding while seeing what you fast forward through helps you get to the right point rather than just skipping blindly like that reddit post I linked suggests.
- Optik-Kate
TELUS Team Member
Hi newio, If a recording is in progress and you press play, the recording will play from the beginning with the capability to fast forward up until the live point.
There is no slow-mo replay at the moment and no differentiation in fast-forward speed. I'll pass these requests to our development, thanks.
Related Content
New Optik Andriod tv box - Need Fast forward/Rewind & skip ahead on guide….
When watching a pvr’d program I use to be able to fast forward / rewind at 1,2,3,4 speeds. Now I can only skip 30 sec or go back by 10 Sec. I can also hold down the “wheel” and it fast forwards/rewin...Solved5.9KViews2Comments
