ajiwani69
6 months agoFriendly Neighbour
Issue with TELUSTV-21T Telus TV Box
Issue with TELUSTV-21T Telus TV Box I have 6 boxes on wifi, and 3 works just fine. The other 3, when I go to live TV, i see a green circle at the bottom right corner and i goes on for a while and e...
5 months agoThe error code suggests connectivity issue. Would you have adjust QoS settings on your router, by chance?
ajiwani69
5 months agoFriendly Neighbour
Good question. My router is on “standard” default settings except for name of the wifi and password. Good thinking in terms of Ethernet and this. I have 2 wifi network- will try the second one.
- ajiwani695 months agoFriendly Neighbour
Thanks for some ideas so far. I should point out that I think there is something wrong with how the Telustv box interacts with Telus since there is no issue with streaming Netflix or Amazon prime on the box only with Live TV. The guide also come down, only when you pick the channel and then it goes into circle and never starts that channel.
