wudao2001
5 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
paulpooco
4 years agoOrganizer
I work for TELUS and reported the issue to an article they had at work about compatibility of the different Gateways and different TELUS hardware about 2 week ago or so.
rcruz
4 years agoFriendly Neighbour
Hopefully they will provide a proper fix on all their routers/boosters/modem because I spoke with 2-3 agents and they don't seem to know or understand what the issue is and how to fix it. I even offered to give them the link to this thread to help them better understand the situation but refused to do so.
