wudao2001
4 years agoNeighbour
- 3 years ago
- Logout
- THANKS ANNA!!!
rcruz
3 years agoFriendly Neighbour
Did you have to pay extra or go through extensive process to swap out your booster to a black router/modem? Looking to have mine swapped out too.
Dnice40
3 years agoNeighbour
Didn't have to swap. Just used the same white tower and went into the settings to "enable bridge".
- rcruz3 years agoFriendly NeighbourI have the wifi 6 booster but it does not give me access to the IP gateway 192.168.1.254 but rather lets me in on the 192.168.1.41 which does not have the LAN menu to enable bridge. I tried using the "admin" username and password on the back of my wifi 6 booster but it just won't allow me to log in.
