wudao2001
4 years agoNeighbour
- 3 years ago
- Logout
- THANKS ANNA!!!
kellyfitchett
3 years agoNeighbour
So I have the NAH and boost wifi 6, when i try and do the above instructions, I dont have the option in LAN to go to BRIDGE. Any suggestions on this setup? Thanks!
rcruz
3 years agoFriendly Neighbour
Same problem here. I do not have the LAN menu on my IP gateway settings therefore I still am not able to connect my redlink to the internet and it is still on Amber. Talked to multiple Telus tech agents and they can't seem to find the issue nor understand what is going on.
- Pruthvi0773 years agoNeighbourHi, just use TP Link network switch, attach with your router or anywhere the Ethernet cable available, and then Redlink attached to TP Link the it should work.
Mine is working that way. - RinSoCal3 years agoOrganizer
I have the T3200M modem as well; so no LAN port bridging option.
For the past day I haven't noticed any offline instances by doing this:
- Log into modem admin acct
- Select Advanced Setup
- Select DHCP Reservation
- Select MAC address of Redlink Gateway
- Select any of the available IP's
Appears to be working for me, but YMMV.
- RinSoCal3 years agoOrganizerYeaaah, scratch the above. Back to 'normal', poor, connectivity once again after a day of smooth sailing.
