wudao2001
4 years agoNeighbour
- 3 years ago
- Logout
- THANKS ANNA!!!
kellyfitchett
3 years agoNeighbour
So I have the NAH and boost wifi 6, when i try and do the above instructions, I dont have the option in LAN to go to BRIDGE. Any suggestions on this setup? Thanks!
RinSoCal
3 years agoOrganizer
I'm trying a bunch of different settings; if I find something that allows the Redlink to consistently be online, I'll report back. Bit of a PITA, wish I wouldn't have sold my routers so I could just bridge and be done with it.
